weld in exhaust or just clamp?
I had been checking around on prices to put on my cat and catback. Got a few prices, but thanks to this board, I kept checking because of you guys saying the prices were pretty high. Thanks!! Found a shop to do it for $60 - $100. Now, my question, is it better to weld in an exhaust or just use the clamps that came with it and clamp it all together? I was planning on welding the cat onto the Y pipe, but from there I don't know. Thanks for the opinions.
Originally posted by gamecockfan04
Use the clamps! If you ever decide to sell it or change it, you can just unbolt the clamps rather than having to cut the pipe.
I agree with the clamps.. I had mine welded and I just wish I had clamped it..
Only worry with the clamps is will the viberate off ???
Clamps will leak and even if you do decide to take it apart it's a pain in the butt to get the clamps off and the pipe seperated because of the heat and corrosion most of the time the bolts will break. The better way is to weld because of no leaks and you can just cut and reweld if you need to remove the exhaust.
carguyshu
Jan 22, 2017 11:19 AM
May 15, 2015 10:43 AM
