Weird stumbling when stoping
Old Apr 14, 2004 | 11:08 PM
Drowned's Avatar
Angry Weird stumbling when stoping
Ok, there's a weird stumbling of rpms when stopping... when you break, the rpms usually stay at around 750-1000rpm right... well SOMETIMES, not always, when stoping, my car's rpms will drop until 500 an the engine seems to miss and stumble... sometimes it even dies (usually when im turning the wheel) and the CHECK GAUGES light comes on... i turn it back on and everything is back to normal
I can keep it from halting by giving it some gas but it wont even out until it goes above 1000-1100 rpm... then everything goes back to normal... it does this warm and cold and just randomly... there's no pattern of any kind and no check engine light
Any ideas on what could be causing this problem? Is my computer going crazy?
Old Apr 14, 2004 | 11:23 PM
cridom's Avatar
i know they are gonna tell you that its your opti but i think it might be the coil or more likely a dirty throttle body.
buy some airintake cleaner or carb cleaner and spray some in there with the engine running and ill get clean.
Old Apr 14, 2004 | 11:26 PM
Greasepunk's Avatar
Try cleaning your MAP sensor, it worked for my low/rough idle. If not check your spark plugs, air filter, plug wires, or it might be a problem with the EGR valve. Dunno...
Old Apr 14, 2004 | 11:40 PM
CamaroSS30thAnn's Avatar
Re: Weird stumbling when stoping
same thing happened to me....dealer told me i needed a new opti....
Old Apr 14, 2004 | 11:42 PM
Drowned's Avatar
Now that you guys mention it... I recently cleaned my CAI... I had to use my car right away after cleaning it and I'm not sure if I waited long enough for the red oil to dry up on the filter Could a drop of that stuff be causing it? What should I check besides de MAF and throttle body and how can I clean my MAF sensor?
Old Apr 14, 2004 | 11:44 PM
25thBird's Avatar
clean it with alcohol is what i've heard. use a q-tip to clean the lines, but careful not to damage the sensors...
Old Apr 14, 2004 | 11:46 PM
Greasepunk's Avatar
What I said was MAP sensor manifold absolute pressure
as for cleaning the MAF probably some electronics cleaner
Old Apr 14, 2004 | 11:48 PM
Drowned's Avatar
Oh... sorry
I just found this thread though...
http://web.camaross.com/forums/showt...ight=clean+maf
So the oil could be causing the hesitation
Old Apr 14, 2004 | 11:53 PM
slowpoke96z28's Avatar
let us know if cleaning the MAF works. do you have a buddy whose MAF you can take right quick to see if that does the trick? remember to unplug the battery so the tables will start back at square one.
Old Apr 15, 2004 | 12:59 AM
turbo_Z's Avatar
I am going with the IAC(idle air control) on this one. It seems to me when you come to a stop and the throttle blades close, the IAC doesnt respond quick enough to allow the volume of air needed to keep the motor running.
Old Apr 15, 2004 | 09:12 AM
Drowned's Avatar
Ok, I'll let you guys know... I'll clean it this weekend
Old Apr 15, 2004 | 09:14 AM
Drowned's Avatar
Hmmm... looks like I have lots of stuff to check... I was also told it could be a vacuum leak...
Old Apr 15, 2004 | 12:26 PM
turbo_Z's Avatar
I would bet a great deal of money that your IAC is clogged up with oil residue.. pull it out and degrease it.
A vacuum leak would have the opposite effect of what you are experiencing. It is my my opinion your car dies from lack of air and a vacuum leak actually sucks in extra air so if you had a leak your RPMs should stick high.. not drop so low it kills the motor.
Old Apr 15, 2004 | 04:43 PM
fozziez28's Avatar
I am also going to go with IAC on this one. If it was your opti, u would experience it more and more frequently, and u would most likely have more problems. MAF is a very good possibility, mine got very dirty and caused my car to stall out at stoplights. A vacuum leak would cause the idle to be crappy all the time. I was gonna say plug wire, because i had a plug wire burn and arc like crazy which caused my rpms to jump around quite a bit. I did all of the above cleaning, including the throttle body and it helped out a great deal, elimated the problem in fact. -Michael
Old Apr 15, 2004 | 06:16 PM
speed76demon's Avatar
arcin mabye?? mine did that and that was it's problem
