Weird rattle when I shut off the car
Old Jun 9, 2005 | 09:30 PM
Gripenfelter's Avatar
Car seems down on power a bit.
It rattles sometimes when I shut it off. Idle seems a bit low.
If I'm driving and I let off the gas, it doesn't matter how fast I'm going, the rpms will drop to 1000 rpm.
Old Jun 9, 2005 | 11:15 PM
Re: Weird rattle when I shut off the car
It also seems to idle low and almost stall sometimes.
Header leak?
Something more serious?
Old Jun 9, 2005 | 11:20 PM
turbo_Z's Avatar
If you have a 6 spd its probably the clutch TO bearing.. mine will rattle if I dont hold down the clutch when I shut it off.
Old Jun 9, 2005 | 11:33 PM
Nope. Its an auto.
Old Jun 10, 2005 | 01:17 AM
Evil Eric's Avatar
i had my torque converter bolts back off the flexplate, that thing made a horrible racket whenever there was slack enough for the converter to vibrate like at idle or when the car was turned off.
Old Jun 10, 2005 | 09:44 AM
Sounds about right. I'll check tonight. Thanx.
Anyone have any ideas about why the rpms drop so fast when I let off the gas?
Old Jun 10, 2005 | 10:02 AM
Z28WannaB's Avatar
Is your transmission slipping?
- Z28wannaB
Old Jun 10, 2005 | 10:07 AM
Doesn't feel like it.
Car just drops down very fast to 900 rpm as if it was stalling but doesn't. Sounds weird driving at 45mph with the car idling and hearing the cam lope.
Old Jun 12, 2005 | 11:19 AM
Turned out that the torque converter bolts had backed out.
Old Jun 12, 2005 | 03:51 PM
Heatmaker's Avatar
Advanced Member
Glad you found the problem... last item I had a rattle like that my Floor pan ended up flying off in the middle of a race after I hit my Nos button.
jj71787
Dec 30, 2014 02:15 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
Klypto
Jul 19, 2002 07:25 AM
