weird rattle
Old Nov 22, 2005 | 11:16 AM
corbraeater's Avatar
Unhappy weird rattle
i get these weird rattle at 2K then it will go away after that but comes right back we i get back down to 2k. i dont know if something is rubbing,but it sound like metal rattling around, i got under the car over the week end and none of the exhaust is hitting anything and it only dose it in drive,please help
Old Nov 22, 2005 | 12:17 PM
morgantoncamaroman's Avatar
Re: weird rattle
check the flywheel for broken teeth or the bolts i had the same problem with my 95 Z28...thats my only lead for you..my car has did sum weird **** that i never would have suspected like that.
Old Nov 22, 2005 | 12:53 PM
Re: weird rattle
so it could be my flywheel, but wouldnt that casue more of a vibaration, not a rattle.
Old Nov 22, 2005 | 01:40 PM
Re: weird rattle
it could cause both but i would i would definatly get that checked because it could also be some bolts that may have came loose and roolin around in there somewhere.
Old Nov 22, 2005 | 02:39 PM
Re: weird rattle
it doesnt soud like it cominmg from the tranny it sound like if coming from the left front side, i could be wrong
Old Nov 22, 2005 | 03:35 PM
Re: weird rattle
different rattles come at different engines speeds,it kinda 50/50 on the cause.mine sounded like it was coming from the right front side when i found out that some teeth had been stripped off my flywheel.it could be the exhaust vibrating agianst something too.Thats a tuff one.have you ever inspected the flywheel or flywheel housing?its simple to take that off it should be "4" 1/2 inch bolts under there.There also is a heat deflector covering the exhaust manifold on the left bank that maybe loose.
Old Nov 22, 2005 | 03:38 PM
Re: weird rattle
when your flywheel was messed up were there anyo ther signs like bad performance, stalling,something else that happened
Old Nov 22, 2005 | 03:54 PM
SweetZRag's Avatar
Re: weird rattle
Another possible cause of the rattle is the element inside the catalytic converter. It sounds like bolts in a can. Try having someone step on the gas while you get your ear near it.
The element can break loose from overheating and the overheating can be caused by the engine running too rich causing too much unburned fuel to reach the element. If this is your cause, check to make sure the engine is not running rich or you will just replace the cat again in a few months.
Old Nov 22, 2005 | 04:02 PM
Re: weird rattle
i agree wih sweetzrag,if its the cat then your lucky.Gut the bad boy
Old Nov 22, 2005 | 05:05 PM
Re: weird rattle
I LIVE IN CALI, KINDA NEED THE CAT ,why would it only make the noise in drive it doesnt do it wen its in N and i rev it to 2k
Old Nov 22, 2005 | 06:23 PM
Re: weird rattle
Yeah no **** livin in Cali can really be a drag when fixin cars.im thinking it has to be something with the tranny because its only doing it while in drive...I live in NC we aint as strict,lol..if it was doing it in n and p id say other wise but thats kinda tricky..thats hard to tell when it comes to trannys and stuff,if you can check the other stuff i told you or you may have to break down and take it to the shop."i know that sucks"
Old Nov 23, 2005 | 07:51 AM
SweetZRag's Avatar
Re: weird rattle
My buddy who owns a muffler shop had me put it in gear (auto) with my foot on the break while he layed on the ground next to the car (not under it!) and he had me give it a little gas. That's when we could hear the rattle while the car was not moving. This might help you isolate if it is the cat or not.
Old Nov 23, 2005 | 03:23 PM
Re: weird rattle
what ended up being wrong with your car, SweetZRag
Old Nov 28, 2005 | 01:43 PM
SweetZRag's Avatar
Re: weird rattle
My case was the element inside the cat. I gutted it until it came time for emmissions inspection and then I replaced the cat.
Old Nov 28, 2005 | 02:35 PM
WhyHelloOfficer's Avatar
Re: weird rattle
I've got pacesetter long tubes with an offroad y-pipe and 3" all the way back and at specific RPMs there is a rattle/vibration that comes from the rear passenger side -- I've come to the conclusion its something that when at the certain frequency of the exhaust at that RPM it just makes it rattle.
I'm too lazy to investigate further..
