weird noise
Old Jan 22, 2003 | 05:57 PM
transamgirl95's Avatar
Question weird noise
hey guys....i know this will be hard to answer ....the last two days when i start my car i hear a weird BBBRRRRR noise ..it lasts all of 2 seconds...what could it be ??.. the car runs fine...i am getting the plugs and wirse done next month ......thanks
oh BTW the noise happens right when the engine first starts....i have even turned off the car waited a few and the noise wasnt there
Old Jan 22, 2003 | 05:59 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
can you elaborate on the BRRRR does it sound like grinding metal, knocking metal... electric motor dieing? what would you assume it is by the sound... how long... wheres it coming from?
Old Jan 22, 2003 | 06:03 PM
hmm i had my door open so it sounded like it came from underneath........it does have a grinding noise ...maybe metal....and seriously ...its sounds like BBRRRR..and lasts as long as u can say it ...happens right when the car cranks
Old Jan 22, 2003 | 06:08 PM
ibanez6rg's Avatar
Maybe you should have someone look at it and let them hear it
Old Jan 22, 2003 | 06:12 PM
frmula1's Avatar
Thumbs up
Transamgirl ahhh the name is slimplistic of everything i want in a woman... A. Female () and B. Owns a trans am.... Marry me?
Old Jan 22, 2003 | 07:48 PM
lol..thanks for that post ...made me smile.... ..anyways .. i was just cleaning my car ..cranked it no noise...ah well....i guess it only happens if the car sits for awhile...i am not to worries..just curious to see what anyone thought ....
Old Jan 22, 2003 | 08:09 PM
kjlvilla's Avatar
It could be your fuel pump, they will turn on for 2-3 seconds to prime the fuel system. It is possible your system is not holding pressure. If it only happens once after sitting for a while, try pulling the fuel pump fuse (after it has been sitting) and listen for the noise on key on, engine off. Then try it with the fuse in. Also have someone listen at the fuel filler neck with the gas cap off. If the noise is present with the fuel pump fuse in and you hear it at the fuel filler neck then have someone check your fuel pres. leak down. It should hold pressure for at least a few hours. If not then possibly your pressure regulator is leaking or check valve at your fuel pump. It may also be your abs self check, but I think this happens after the engine is started, I would have to check on this.
Old Jan 22, 2003 | 08:40 PM
JaxZ's Avatar
Was going to suggues the same thing... sounds like the fuel pump to me... When you start the car, just turn the key to the ACC position, before engaging the starter... you should be able to hear the pump, and the noise if thats the problem.
Old Jan 22, 2003 | 08:56 PM
Terran2k's Avatar
hmm a Transam girl from sarasota. they must be popular over there, i knew a transamchic on AOL from sarasota once. but this Brrrrr noise, could it be your fans?
Old Jan 22, 2003 | 09:03 PM
1996 | Z28 SS's Avatar
Does it happen only when it's cold?? Cuz mine makes almost that exact noise, but only when it's cranked in the cold weather, then it runs fine.
Old Jan 22, 2003 | 09:08 PM
Jcb890's Avatar
u said the BBBRRR noise stays on for as long as you can say it...i can say BBBRRR for a long time actually...sorry i'm just being a wise@$$, i really have no real help to give you, a girl w/ a trans am...my last girl didnt like my car...i was like wtf, needless to say we're not together ne more
take it easy guys...and girls
jake
Old Jan 22, 2003 | 10:21 PM
frmula1's Avatar
i use to live just down the road from sarasota in charlotte county... bet its nice and warm there.... just took my formula for a romp... its a toasty -1 outside... and as for a girl with a trans am...
Old Jan 22, 2003 | 10:25 PM
Mtrhds94Z's Avatar
Could be the AIR pump that runs a few min at startup...
In fact mine was loud tonite and almost blew the fuse[lights dimmed] it is 15 degrees here tho...
They can be noisy at times..
Old Jan 23, 2003 | 04:48 AM
thanks for all the suggestions .....it has been cool here for florida ...but we had a high of 71 yesterday so i dont think its cause of the cold...it is going to be 26 degrees tonight lol....weird ....but thats florida...she runs fine though so surging ....in fact i am off to the track tonight ......i will keep u updated on my BBRRRR noise .. ...thanks everyone
Old Jan 23, 2003 | 08:30 AM
DDZ/28's Avatar
My car's been doing the same thing and it's definitely cold related. It lasts only a couple seconds, so I can never pinpoint it. I disconnected my air pump a couple days ago(fuses blowing on that) & the noise is still there.
This morning was really really cold (gotta love Canadian winters ) and it lasted for a good minute. I popped the hood and it seemed to be coming from the alternator
I'm guessing it's that...makes sense too since the noise increases with the throttle.
Is that a possibility?
Nayr
Mar 3, 2023 08:34 PM
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
colts0455
Jul 7, 2015 07:19 PM
