onebad636 |
05-02-2007 08:08 PM |
Weird Ignition problems ( kinda long )
Ok, first of all I was driving and my opti went out and my car would not start. So I swapped the opti out with a new accel one from summit. ( got it for $200 due to price matching!! Thank you JC SH*TME ) Then it started and ran fine up until about 5,000 rpm where it would start popping and backfiring. I put new NGK TR55 plugs in it with no luck. I tried changing out my MSD coil and ignition module but it still did not fix it. I changed the coil wire and it seemed to run ok. We left for the drag strip when the car died along the interstate. A wire pulled out of my opti harness so we had that fixed. Then it started and then died again. We had to change out the coil with a new one and it ran ok. We made it to the track with it running perfect. The first run it started popping and running like crap and ran a 13.11 @104.6. I wasn't sure if it was hitting the rev or running like crap so I bumped my rev up to 6200. The next run it really ran like crap and I had to let off of the gas. After it cooled off it would not start again. I trailered it home, ordered a new summit opti harness and when I installed it, it wouldn't start. NO SPARK. I unplugged the ignition module and plugged it into the old one and it fired right up. So I unplugged it and plugged it back into the new one and it fired up again????? WTF is wrong with this stupid thing?
