Weird Coolant Problem
My car has been acting a little weird lately. Ive intermitantly had a low coolant light on in the dash. I had the coolant system flushed out a month ago and after the system was flushed the low coolant light was still on...thus bad sensor correct? Now all of a sudden the car heats up very fast to about 220 and stays there with no difference in traffic or on the highway. Today I tried to turn the heat on and it only blows cold air? The coolant level is fine so whats up? Is it the heater core? Thermostat?
Re: Weird Coolant Problem
the coolant isnt cycling through the block...like someone stated above...you probably have air in your system...thats why when coolant is being added (with the car running) you are supposed to loosen the valve on top of the line by the waterpump and i think there is another one on the other line as well...loosen those up while adding and that pushes and releases the air out...and also allows you to fill it up all the way with coolant. (BEWARE - WATER WILL SQUIRT OUT) So have a rag nearby and watch ur eyes.
Cory
Cory
it's really easier than it reads.
you can do that too...I only do it with the car running cuz I thought I read somewhere that the engine needed to be at operating temperature for some reason?
Cory
Cory
Cory
Cory
Dylan Latshaw
Mar 21, 2015 09:48 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
