Weak point?
Old Jan 2, 2004 | 06:39 PM
TRIPLE G's Avatar
Weak point?
I was wondering what is the common weak point of a LT1 (93) bottom end. What tends to go first when you start to push the max HP from it in stock form.
Old Jan 2, 2004 | 09:13 PM
Josh-'04 GTO's Avatar
Re: Weak point?
I would say rod bolts, then pistons. The crank and rods are reasonably decent, but factory rod bolts are no match for ARP's, and factory hypereutectic pistons are the next weakest link in a stock bottom end, especially with a power adder.
Thats not to say you still can't get some good power and life out of it.
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
alliance12364
Sep 17, 2015 08:43 AM
