Waterpump Sensor
Old May 14, 2008 | 09:04 PM
lt1loudmouth07
Guest
Posts: n/a
Waterpump Sensor
I have been trying to find out why my car is hard starting all the time my fp is perfect i have new opti and plug wires coil and fuelpump. After i let my car sit at night and start it up in the morning it fires right up. But when i am driving it about 30miles and let it sit for anywhere between 1-3 hours it takes like 6-7 turns before it starts i have been reading about the sensor on the waterpump causeing this to happen could that be whats doing it. and does anyone know the part number at autozone for the sensor on the waterpump
Old May 14, 2008 | 09:07 PM
19z28camaro02's Avatar
Duralast PN SU109. But don't forget there is one on the Left hand side of the engine(driver-side), near the front of the header.
Old May 14, 2008 | 09:11 PM
lt1loudmouth07
Guest
Posts: n/a
sensor
yea that is the one for the gauge thats already been replaced when i replaced my headers. That part number u gave me is for the one on the waterpump right ?
Old May 14, 2008 | 09:37 PM
They're the same.
Old May 14, 2008 | 09:38 PM
If one of them is failed, it will give the computer a false signal of something like -40 degrees below zero which causes an extremely cold start condition. It is possible that that is what is causing your car to flood.
Old May 14, 2008 | 09:41 PM
96' Formula WS6's Avatar
it could be that switch or leaky injectors
Old May 14, 2008 | 09:44 PM
lt1loudmouth07
Guest
Posts: n/a
injectors
i checked that there are no leaky injectors. I have been dealing with this problem for some time now its really making me mad and if its just that sensor i will be ticked lol.
Old May 14, 2008 | 09:47 PM
lt1loudmouth07
Guest
Posts: n/a
sensor
Would that sensor cause the car to run like crap too ?
Old May 14, 2008 | 09:52 PM
mrmint69's Avatar
I changed my plugs and it went from almost not starting to a flip of the ignition switch every time. The one in the water pump is the only one to worry about. It use to die randomly until i replaced it.
Old May 14, 2008 | 09:54 PM
The one on the block should be the low level sensor. I think.
Old May 14, 2008 | 09:55 PM
Why are you running 30lb injectors with a CAI and LTs?
Old May 14, 2008 | 10:39 PM
Originally Posted by 19z28camaro02
They're the same.
No, they are not. The one on the water pump uses two pins and a 5v reference signal and ground from the PCM. The one on the head uses one pin and a 12v bias from the gauge panel.
Check the readings of the sensor with a scanner to prove it is ok or not.
Old May 15, 2008 | 07:57 AM
ghost97ta's Avatar
water pump sensor
i just had the water pump sensor go bad and only thing that happen.
was my fans just did not come on it ran just fine i just had to use the ac to get the fans to turn on . might have some thing else wrong
have you scaned it for codes
Old May 15, 2008 | 09:02 AM
94zgreenmachine's Avatar
Low level coolant sensor is on the radiator , passenger side.
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
MikeWhitener
Aug 2, 2015 06:17 PM
zajones
Jul 30, 2015 02:18 PM
