Waterpump
Old Jul 5, 2004 | 01:02 PM
1FstFormulaV8's Avatar
Waterpump
Call me dumb. But, how does the waterpump work on an LT1? There's no pulley or anything to turn the impeller. How?
Old Jul 5, 2004 | 01:35 PM
Jeremy_30th's Avatar
Camshaft. This creates a question from me, How much power could you free up with a electric pump?
Old Jul 5, 2004 | 01:41 PM
Somnambulist's Avatar
some people see ~10rw
Old Jul 5, 2004 | 01:52 PM
I will defenitly wait for mine to break, the cost of those pumps aren't worth 10 ponies
Old Jul 5, 2004 | 01:54 PM
RamAir95TA's Avatar
Is the cost of a catback exhaust worth 10HP?
Old Jul 5, 2004 | 02:04 PM
good point. most people go with an elec. water pump during a cam or opti install, usually depending on what timing set they go with. ~$200 for an elec. water pump isn't that bad for ~10 to the rear wheels...
like mr ramair95ta stated, we usually spend more on a catback...
Old Jul 5, 2004 | 02:48 PM
I see where your going but when I bought my catback it wasn't for 10hp it was in preparation for my future top end build. But yeah point taken
Old Jul 5, 2004 | 04:50 PM
jtk's Avatar
jtk
I would think there would be a problem with the water pump drive gear with out the mechanical pump connected to it. since the water pump holds up one end of the water pump drive... but I guess its not realy a problem since there have been many people that have done it.
Old Jul 5, 2004 | 05:05 PM
RamAir95TA's Avatar
The waterpump drive gear is supported in two spots, the bearing in the block and the timing cover seal. I completely removed the drive shaft when I did my Cloyes install.
Old Jul 5, 2004 | 06:14 PM
Ekof96Z28's Avatar
If I go with a cloyes timing chain where does the timing cover need to be clearenced?
-Eric
reww86
Aug 29, 2015 06:04 PM
MikeWhitener
Aug 2, 2015 06:17 PM
jwade88
Jun 14, 2015 09:38 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
