View Poll Results: EWP
CSR 30-37 GPM
45.16%
Meziere 43 GPM
19.35%
Meziere 55GPM
35.48%
Voters: 31. You may not vote on this poll
Water pumps
Old May 13, 2008 | 02:38 AM
red1984's Avatar
Water pumps
What pump would you use?
Old May 13, 2008 | 04:08 AM
luckyou03's Avatar
csr for over a year now
Old May 13, 2008 | 07:22 AM
DAVE00's Avatar
If it's a DD then stick with the stock manual pump as it flows much better and less prone to failure. If not then the Meziere.
Old May 13, 2008 | 01:14 PM
96' Formula WS6's Avatar
The only time the stock pump flows more is at highway speeds. I have the mez 43gpm one and cruising at about 85 on the way to orlando it never came close to the middle line. And a got 9 rwhp out of it
Old May 13, 2008 | 04:34 PM
lt1-xjs's Avatar
I had an original CSI pump on for 4yrs. 3mos., 26,000 miles with no issues. It made noise 2 weeks before it blew a fuse. Put my spare on in Sept. CSR repaired it for $80.,(a new CSR pump).
Old May 14, 2008 | 03:03 PM
G. McDonald's Avatar
EWP side effects
Plus - you get to use a much cheaper and better timing chain (Cloyes - as compared to the very expensive stock high performance timing chain set) plus, you eliminate a potential oil leak from the timing cover, a potential coolant leak from the weep hole (as compared to the stock water pump configuration - which can bugger your opti) and you gain 10 - 11 rwhp and about the same rwtq. It's just shy of a miracle. I believe it is also a credible method of birth control.
Old May 15, 2008 | 12:27 AM
red1984's Avatar
That is the reason I am going to use a EWP. I have hurd good thing about CSR and Meziere. The only thing I am having a problem with is choosing which pump to buy.
Old May 15, 2008 | 08:06 AM
ghost97ta's Avatar
water pump
i have been using csi water pump for a year now and it has been good to me. and i used a painless wiring kit to hook it up.
Old May 15, 2008 | 12:12 PM
GLICKGLOCKMEX's Avatar
CSR FOR OVER A YEAR AND NO PROBLEMS.THIS CAR IS A DD AND A TRACK CAR.the way i see it is if it only lasts for 2 years i still got my moneys worth!!!
Old May 15, 2008 | 03:23 PM
silver97Z's Avatar
CSR for a couple of months now with no problems...DD
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
