water pump wiring problems!?
Old Sep 27, 2005 | 07:21 PM
BLUETOPTA's Avatar
Angry water pump wiring problems!?
I have had my CSI water pump hooked up to my car for almost 3 years now. i used this scematic to hook it up.
http://ken.lowrance.com/Projects/CSI.../Schematic.jpg
It stoped working the other day
I found it blew the 15 amp fuse. I checked every thing, and it will still work, but it keeps blowing fuses? I tried to run it with out the fuse and the wires get hot. What is wrong here? Is the pump motor dead? I mean it will run, but it blows the fuse. I replaced the relay also.
Cant figure this out???
Old Sep 27, 2005 | 08:32 PM
BLUETOPTA's Avatar
Re: water pump wiring problems!?
TTT should I call CSR or CSI or what ever they are? Think they can help?
Old Sep 27, 2005 | 08:48 PM
M93Z's Avatar
Mine did the same thing about a month ago, I was on the road and all I had for a spare was a 20 amp fuse so I used it and it worked fine. The car isn't my daily driver and after a few weeks I forgot about it as it ran fine on the occassional trip around home. Last week it blew again and when I replaced the fuse it would only last about 5 minutes. I checked the wiring and found the wire was getting hot. I pulled the pump and found the impellar [sp?]teeth were chipped as if they were hitting the housing. The shaft seems tight but it apparently is wobbling and rubbing the housing under load. Mine was in for a little over 2 years, maybe 4 - 5K miles. CSR will rebuild it for about $60., I bought a new one and will have the broken one rebuilt for a spare.
Old Sep 27, 2005 | 09:15 PM
Hawk's Avatar
sounds like your electric motor is binding up, therefore drawing more current. I'd take it off the car and take a look, if it's still under warranty, send it in.
Brian
Old Sep 28, 2005 | 01:07 AM
transamdude95's Avatar
My guess is the impeller came loose and that's why the fuse is blowing. Send it back to CSR if that's the case and have them fix it for you.
Old Oct 11, 2005 | 04:38 PM
M93Z's Avatar
FYI, I installed the new pump from CSR...........ran fine for about an hour, blew a fuse and wouldn't run at all. Pulled it apart and found the impeller had come off of the shaft.
Old Oct 11, 2005 | 05:56 PM
BLUETOPTA's Avatar
Yea im all set now. The seal on the inside of the pump had a leak, and all the internals off the pump got coroaded with coolant. $60.00 to fix throuh CSR. They have Great customer service.
Old Oct 11, 2005 | 06:23 PM
$60!!!!!!! They should have fixed it for free!
Old Oct 11, 2005 | 08:16 PM
Dave89IROC's Avatar
why? he's had it for three years, do they have a warranty that is longer then that?
Old Oct 11, 2005 | 09:30 PM
Ok, granted I missed that part of the equation. I still think they shouldn't have charged that much for fixing their product. The only thing that should go bad with these(IMO) is the motor going bad from amount of use. But it is what it is.
Old Oct 12, 2005 | 11:19 AM
BLUETOPTA's Avatar
Im not upset, Had it in the car for 3 years. This is a summer driven car, not a drag garrage queen.
Old Oct 12, 2005 | 12:27 PM
JasonK94Z's Avatar
I think $60 is their standard fee for a rebuild on these pumps. I'm glad they do that! It beats having to pay out another $160 for a new one.
What was their turnaround time?
Old Oct 12, 2005 | 01:30 PM
I bet they had it out the door the same day they received it.
Old Oct 12, 2005 | 05:13 PM
BLUETOPTA's Avatar
Yup 1 day turn around. It was great! I wish that one certain major PCM tuning company was as close to as fast.....
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
pologreen97z
Dec 2, 2014 10:42 AM
