Water pump replacement question
Old May 24, 2006 | 02:38 PM
Jon94Z's Avatar
Ok I have the old water pump off and I'm ready to put the new one on except I can't get the water pump driveshaft coupling off the old water pump. Isn't it supposed to just pull off? I tried prying it out with a screwdriver and broke the tip off and I tried using some pliers and it hasn't moved at all. Here are some pictures of the old water pump with the coupling and the new one without it. I hope I don't have to get a new one from the dealership, they wanted $35!
Old May 24, 2006 | 03:31 PM
firefighter's Avatar
Re: Water pump replacement question
coat it with some PB blaster or WD-40 and let it sit for awhile then try
Old May 24, 2006 | 03:32 PM
OBE1 95Z28's Avatar
Spray the inside of the coupling with penetrating oil and let it soak in.
Old May 24, 2006 | 03:44 PM
Jon94Z's Avatar
Good idea guys, I have some PB blaster left over from my friends LT install, I'll give that a try.
Old May 24, 2006 | 06:26 PM
rhummer37's Avatar
Mine practically fell off when I had the pump off.
Old May 24, 2006 | 09:21 PM
Jazsun's Avatar
I guess my stuck to the motor part, cuz when I took my pump off I never saw that thing, and when I put it back on it just slid back in again.
Old May 24, 2006 | 09:37 PM
Forgedlt4's Avatar
someone probably put it on without lining the splines up.
Old May 24, 2006 | 10:11 PM
Jon94Z's Avatar
Ok I just got back from my friends house and we got it out. I tried the PB with no luck so we put it in a vice and hammered on it and it finally came off. Thanks for the help guys.
Old May 24, 2006 | 10:44 PM
neil350's Avatar
Thats way we roll man, if you need a hand tomorow just let me know
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
