Water Pump Question
Old Jun 2, 2008 | 06:07 PM
ZaneO's Avatar
Water Pump Question
This is likely a dumb question (and I didn't find what I needed through search), but I'm unsure. I'm in the process of changing out my water pump and need to know if you have to change the water pump cover seal (GM #10217886)?
So far, I've got the old pump off, and the coupling is rusted onto the water pump itself, so I got a new one. I just want to make sure everything is right before it all goes back together.
Old Jun 2, 2008 | 06:25 PM
caldercay's Avatar
If you're in there, you might as well - if it goes 5k miles after you put the
new pump on, you'll wish you did It's a $5-$10 part.
Old Jun 2, 2008 | 06:27 PM
Just do the seal install correctly or you will pulling it all back out again. (you probably found tips in your searches)
Old Jun 2, 2008 | 08:50 PM
ZaneO's Avatar
I did...thanks guys.
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
