Water pump question
Old Apr 3, 2008 | 04:09 PM
mike445's Avatar
From: Wasaga Beach, ON (formerly Ft. Lauderdale,FL)
Water pump question
If you replace the water pump does it come with a thermostat?? I was wondering if when the mechanic put on my new water pump he didn't use my 160* thermostat!!
Mike
Old Apr 3, 2008 | 04:27 PM
Bluovlh8er's Avatar
some do come with a 180* thermo. i know the one i got from summit did...
Old Apr 3, 2008 | 04:29 PM
mike445's Avatar
I'll bet that's one of the reasons my fans come on when the car warms up!! I have the fans programmed for a 160* thermostat!!! Thanks. Im gonna have it changed just to make sure. All the fan problems started right after the water pump was changed.
Old Apr 3, 2008 | 09:22 PM
Maverick_997's Avatar
yeah most come with the stock 180 degree therm.
is their any thermostats lower than 160? when i ran no thermostat for a couple days i felt a little more horsepower. or is runnign no termstat bad for the car anyways??
Old Apr 3, 2008 | 11:22 PM
The_Bishop's Avatar
Yes, very. The motor will not warm up enough, and will run rich. The oil will become gasoline fouled, which will cause it to not lubricate as well and sludge deposits will form.
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
