water pump question?
Old Jan 21, 2008 | 12:58 PM
lilchrisgangsta's Avatar
I drive a 93 z28 camaro.
The other day my serpentine snapped, with the loss of power steering and alternator.
I noticed the water pump, which usually has a belt powering it, did not, it doesnt even have a pulley. Its the first time ive ever seen that kind, im not huge on engines, just know basic stuff. I talked to someone, and he said it was an electric water pump, or.. it was powered by the driveshaft.
Im just curious if anyone knows what im talking about, and if its standard on a 93 camaro.
Old Jan 21, 2008 | 01:07 PM
z28camaro1090's Avatar
I have a 93 Camaro also and there is no belt powering my water pump. so don't think anything isn't normal with your camaro
Old Jan 21, 2008 | 01:31 PM
Wild1's Avatar
It is turned by a gear on the other side of the timing cover. The gear is turned by the cam gear which is then turned by chain from the crank.
A few FYIs on the water pump:
It is a decent set up although some convert it to an electric pump.
The other issue that has occured are normal wear and tear to the seal behind the water pump to the timing cover. It is paper and sometimes tears and leaks oil. If you have a mystery leak up front then you may want to check there.
Old Jan 21, 2008 | 03:40 PM
Stl94LT1's Avatar
Old Jan 21, 2008 | 03:45 PM
Sweetred95ta's Avatar
Originally Posted by lilchrisgangsta
I talked to someone, and he said...it was powered by the driveshaft.
I would never ask car advice from that person again.
Old Jan 23, 2008 | 09:03 AM
Wild1's Avatar
I believe it's technically called the water pump driveshaft coupling.
http://shbox.com/ci/water_pump.jpg
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
