Water Pump and Opti
Is it a good idea to replace the Coolant Temp. Sensor, the one used by the PCM, when doing a Water Pump replacement? I am changing the water pump and Opti. Anything else you would recommend replacing while I'm in there?
Blood type Z28
Apr 8, 2015 11:34 PM
