Water Pump Impeller Shaft
Old Jul 21, 2005 | 07:20 PM
transamdude95's Avatar
I have been pounding on this with a punch/hammer trying to get it out and it isn't budging..... any advice?
Old Jul 21, 2005 | 08:57 PM
Ken95Z28's Avatar
Re: Water Pump Impeller Shaft
Here is a guide that I done along time ago.
CSI Guide
Just make sure you are hitting the right way.
Old Jul 21, 2005 | 09:48 PM
I'm hitting it in the right spot with the punch... it just isn't moving. I've been using that guide somewhat and another one(Meziere). I'll keep pounding away, hopefully it'll happen lol. Any other advice?
Old Jul 22, 2005 | 02:16 PM
Here's some pics.. maybe I missed something?
http://i3.photobucket.com/albums/y75...mpShaft001.jpg
http://i3.photobucket.com/albums/y75...mpShaft002.jpg
http://i3.photobucket.com/albums/y75...mpShaft003.jpg
Old Jul 22, 2005 | 02:24 PM
HBHRacing's Avatar
if you can't get it like that you are going to need to have it pressed out.
Old Jul 22, 2005 | 03:26 PM
GetaZforgetGT's Avatar
Not to be argumentative but it can be done that way as many other have successfully done it.
I will agree that a press is the preferred method and probably the most time effective assuming a press is close by.
If you decide to use the hammer and punch method just make sure that you are driving it from the impeller side towards the back of the pump housing.
It is also best to support the housing as much as possible without obstructing the shaft from moving backwards.
Old Jul 22, 2005 | 11:11 PM
Punch/Hammer combo isn't going to work. I'll be taking it to a machine shop to have it pressed out.
Old Jul 23, 2005 | 08:15 PM
Ken95Z28's Avatar
That looks like it's in there pretty good.
A press should help our for sure.
Old Jul 23, 2005 | 11:17 PM
Got it pressed out this morning for $10
It was definately in there good. Either the housing was going to break or the shaft was coming out lol.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
