Water Pump Hose Question! Urgent Help, Please!!
Old Feb 29, 2004 | 12:22 PM
joecool72's Avatar
I blew a coolant hose on my '96 Z28 Friday nite where I lost about 75% of my coolant. I have the car on ramps today but I'm puzzled with the hose that broke loose.
If you're facing the front of the car it's the hose connected to the left bottom side of the water pump with a hose clamp. About a couple of inches down on this hose there's two silver machined compression fittings and inside this piece is a spring for some reason. This is the part of the hose that blew out on me.
It looks simple enough to remove the hose clamp going to the water pump but after I followed the hose it ended up routing somewhere underneath the A/C condenser to another machined compression fitting.
Any idea what this part is and how easy it is to replace everything associated with this hose??? Is it neccessary to cut a portion off and tie it into the existing hose???
Thanks in advance!!!
Old Feb 29, 2004 | 12:44 PM
OBE1 95Z28's Avatar
That's one of your heater hoses that continues all the way to the firewall. No sure if you can "splice" them.
Old Feb 29, 2004 | 02:24 PM
joecool72's Avatar
Ok, I went through my shop manuals and it's got this listed as the Flow Control Valve inline in the hose connected to the Heater Inlet Pipe on the Water Pump. All the auto part shops around here do not carry this part so I'm going to have to contact my dealer come Monday. I'm just curious how I can reconnect this part to the hoses without having to replace the entire line that runs to the firewall.
Any thoughts/ideas???
Old Feb 29, 2004 | 02:36 PM
Mtrhds94Z's Avatar
A search for 'heater hose' worked wonders..
I posted a lot of good info in some of these posts about hoses and the swaged on clamps [remnoval with Dremel, etc etc]
http://web.camaross.com/forums/searc...der=descending
Old Feb 29, 2004 | 07:54 PM
joecool72's Avatar
Not to sound sarcastic, either , but I read your article prior to posting, very informativem, thanks. Looking for other opinions on the subject, too.
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
