Water pump fitting
Old Jan 28, 2005 | 06:38 PM
LewisW96's Avatar
Question Water pump fitting
Looking at the front of the engine, What is the fitting coming out of the WP at the 2:00 position? A hose runs from the fitting to the radiator. My car does not have a oil cooler and I have seen them plugged on other cars. I'm installing an ATI D1-SC and it calls for the tube coming out of the WP to be rotated 90* up. I was wondering if I could just plug that fitting and not have to worry about running a coolant line over the head unit.
Old Jan 28, 2005 | 07:01 PM
Re: Water pump fitting
Assuming you mean the smaller hose at about 4 o'clock, yes you can plug that. It is where the bypass hose goes to the radiator on cars with no oil cooler.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
pologreen97z
Dec 2, 2014 10:42 AM
