water pump drive orings??
Old Jul 25, 2007 | 10:01 PM
mkent's Avatar
Are the o rings on the water pump drive shaft on each side of the coupler just regular orings or are they some special ones made for this particular application from GM?
http://shbox.com/ci/water_pump.jpg
I'm talking about part 156 in view A of this diagram from shoebox's website.
I took the waterpump off last December and I don't recall the orings at all. My gasket/seal kit does not seem to include specific orings for this part so I'm a little confused.
Old Jul 25, 2007 | 11:02 PM
2QUIK6's Avatar
Its labeled a "seal" be it really doesn't seal anything. I think its just used to give the shaft a little cushion for vibration and noise, and it does help hold the shaft coupler in palce and on the shaft during wp install. Any o-ring that fits snugly over the shaft should work.
Old Jul 26, 2007 | 08:36 AM
wrd1972's Avatar
I just got plain Jane orings from the bulk box at the parts house, as long as the coupler fits snug you are golden.
Old Jul 26, 2007 | 10:47 AM
mkent's Avatar
Should the coupler fit OVER the orings or should the orings be just large enough in diameter than they do not go inside the coupler? The ones I used fit snug over the shaft but the material diameter is large enough to seat against the outside edge of each end of the coupler
Old Jul 26, 2007 | 01:28 PM
2QUIK6's Avatar
coupler goes over the orings just slightly.
Old Jul 26, 2007 | 02:01 PM
The o-rings "seal" out dirt from the splines. They should have a little grease on them.
Old Jul 26, 2007 | 02:09 PM
feenix88's Avatar
What kind of grease?
Old Jul 26, 2007 | 02:40 PM
A dab of bearing grease should do.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
