Water pump drive o-ring seals?
Old May 1, 2010 | 05:55 PM
jasonface's Avatar
Just wondering, WHAT are they actually sealing? Had to do my opti last week, and was looking at those o-rings when I was putting the new o-rings on the water pump shaft, and on the drive stub coming out of the front of the timing chain cover. There are already seals on both the pump shaft, and on the drive stub, so what gives? Are the o-rings just to keep dirt and grit out of the splined coupler?
I'm a little OCD like that, I want to know not only that something works, I have to know WHY it works. Thanks!
Old May 1, 2010 | 06:07 PM
96capricemgr's Avatar
answered your own question.
Old May 1, 2010 | 06:19 PM
jasonface's Avatar
Thanks man, it just seems overkill. Not much going on in that area. It's pretty well-protected back there. Then again, I guess for your aveage "beater" that never sees an engine wash, crud could get back in there.
Old May 1, 2010 | 07:02 PM
RamAir95TA's Avatar
I think they also help to isolate the opti drive from the cam.
Old May 1, 2010 | 10:24 PM
The water pump o-rings?
There should be some grease applied to the coupler and splines and the o-rings keep the grit out, so they don't wear out and strip.
Old May 1, 2010 | 10:38 PM
RamAir95TA's Avatar
Beer + posting = bad.
Old May 1, 2010 | 10:56 PM
I knew there had to be some distraction.
Old May 2, 2010 | 03:59 AM
jasonface's Avatar
Yeah, but Saturday night + beer = good
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
