Water pump drive install
Old Oct 1, 2006 | 07:22 PM
bingo's Avatar
What is the best way to install a water pump drive in the block. I ordered a new one and I don't want to damage it. pics would be nice if anyone has them.
Old Oct 2, 2006 | 03:12 PM
bingo's Avatar
Re: Water pump drive install
Anyone know? Can I even do this with basic tools?
Old Oct 2, 2006 | 03:14 PM
FryedClutch's Avatar
i am perty sure you have to take off the intake and there are a couple torx screws that hold on the retaining plate
i may be wrong but im perty sure thats what you have to do
Old Oct 2, 2006 | 03:53 PM
bingo's Avatar
This is going in a rebuild. I have the old one out, I just don't know the best way to install the new one.
Old Oct 2, 2006 | 06:18 PM
respectirocz's Avatar
if your refering to the driveshaft with the gear that meshes with the cam gear
then the best way to install it is gently
just take a rubber mallet, eye it in place, a couple of taps and its in good
then put in the two torx screws
Old Oct 2, 2006 | 06:55 PM
bingo's Avatar
Won't that push the shaft into the bearing. I figured there was a way that would put the pressure on the outter area of the bearing. I just don't want to damage it. GM doesn't give them away.
Old Oct 2, 2006 | 07:01 PM
FirebatLT1's Avatar
I dont know what part you are talking about but if its metal, heat it up with a heat gun and maybe it will go on a little bit easier.
Old Oct 2, 2006 | 07:22 PM
bingo's Avatar
It is the gear that runs off the cam gear to run the waterpump. The part is 10219554 and there is a pic on gmpartsdirect.
Old Oct 2, 2006 | 07:24 PM
FirebatLT1's Avatar
oh, nevermind
Old Oct 3, 2006 | 08:21 PM
bingo's Avatar
I remember seeing an article somewhere about installing the drive with bolts to pull it into the block. I think it was the LT1 buildup for project snowball in GM High-Tech magazine. Does anyone remember this article?
Old Oct 3, 2006 | 08:51 PM
try tapping it gently with a rubber mallet like i said and you'll see how easily it goes in
it really goes in so easy you wont even worry about damaging the bearing
Old Oct 3, 2006 | 09:03 PM
bingo's Avatar
I will try that. I was just worried about damaging it. This rebuild has got way out of hand. Machine work, heads, cam, gaskets and other stuff. It seems when I think I have everything, something else turns up. This 355 better go like stink.
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
