Water pump drive gear & bearing.
I'm going to be doing a rebuild soon. Figure I'll replace the water pump drive gear & bearing. I have yet to take it apart. Are these one piece or two?
Anyone have the part number(s) for this?
thanks
thanks
Re: Water pump drive gear & bearing.
If I'm taking the engine completely apart I'm going to replace a number of parts, including all bearings. Not to mention this surface will quite often leak due to a grove worn into the shaft from the tc seal.
30 minutes of searching and I couldnt find it, until 2 minutes AFTER I started this thread!
GM PART # 10219554
GM PART # 10219554
