water pump bolt
Old Aug 1, 2005 | 04:11 PM
Jeffs94Z28's Avatar
water pump bolt
whats the best way to get to that bolt on the passenger side that is underneath the pulley that holds the waterpump in?
Old Aug 1, 2005 | 04:20 PM
Crazy95Z's Avatar
Re: water pump bolt
Simple! Use a regular socket and a 6" extension. Loosen it till its finger tight, pull off the socket and finish with your hands.
Old Aug 1, 2005 | 04:33 PM
Jeffs94Z28's Avatar
Re: water pump bolt
will a 6" extension work to put the bolt back in with?
Old Aug 1, 2005 | 04:51 PM
RedThunder1994's Avatar
Re: water pump bolt
Just reverse the process. Put the bolt in the hole, start threading it in until you have enough clearance to put the socket on the head of the bolt and tighten it down.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
