water pump
Old Apr 12, 2003 | 11:40 AM
Kearn's Avatar
water pump
my water pump started to leak a week ago, so i had to change the pump, when i changed the pump there wasn't a plug wire that connects to the sensor on the water pump, the sensor is on the water pump but it is unplugged and i don't know where the plug wire is, am i okay? do i really need that sensor to be plugged in?
thanks for any help
Old Apr 12, 2003 | 11:43 AM
stevil's Avatar
Thats probably your coolant temp sensor. I'd try to find where it went.
Old Apr 12, 2003 | 12:32 PM
jasons93z's Avatar
does your temp gauge work, if not, its the temp sensor as said above.
Old Apr 12, 2003 | 03:11 PM
Mtrhds94Z's Avatar
LT1's have 2 coolant sensors.. one on the drivers side head for the gage, and the one you refer to on the WP for the PCM...
The latter is very much needed!
Old Apr 12, 2003 | 04:11 PM
Kearn's Avatar
i found the wire and had soldered it together, i have everything put back to place, and the coolant filled up (maybe even a little too much). Now my Service Engine Soon light came on. What could flip that switch. it was not on before i worked on the water pump but after installing the new one it came on.
Old Apr 12, 2003 | 05:45 PM
stevil's Avatar
I know when I did my waterpump, I started the car after filling up coolant, ran it for a few seconds, and I think it flashed a "Check Coolant" light or something like that, I forget... never seen it since. Might have been the SES though. I bled the system of air, added more coolant, bled, etc. It went away... maybe thats your problem?
Old Apr 12, 2003 | 07:19 PM
Mtrhds94Z's Avatar
I would think you would have had an SES due to that sensor NOT being hooked up to the original pump?
Sure you plugged the MAF and IAT sensors in?
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
