Water in oil??
Old Mar 6, 2007 | 07:43 PM
tcc974's Avatar
Unhappy Water in oil??
I have been removing the driver side head to get some broken off bolts drilled off. In the process, I have noticed a few things. There is milky water on top of the driver side valve cover as well as the front of the intake. However there is nothing on the passenger side or in the lifter valley. The driver side head gasket showed no signs of damage.
I have been trying to avoid removing the passenger head but is it possible that this is the gasket giving me problems? Is there any other way for the water to get in the oil. The car ran great with no smoke so that is why I don't think it would be the other head gasket. Any ideas?
Old Mar 6, 2007 | 08:29 PM
tcc974's Avatar
ok just drained the oil pan, definitely not condensation. It is possible that something with the oil cooling system is bad? whether it be in the water pump or radiator?
Old Mar 6, 2007 | 09:47 PM
LiENUS's Avatar
I'm pretty sure its not your water pump... what bolts were broken?
Old Mar 6, 2007 | 09:54 PM
tcc974's Avatar
the exhaust manifold bolts. Dropped the head off at the machine shop today for them to drill them out.
Ok not the oil cooler, looks like I am pulling the passenger head tomorrow morning.
Old Mar 6, 2007 | 10:09 PM
speed_demon24's Avatar
head gasket > u
Old Mar 7, 2007 | 01:37 AM
STREETLETHALZ's Avatar
check the block for cracks around the lifter valley as well, i have a friend that got owned by his block.
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
willismoons
May 27, 2015 04:03 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Nickster 7
May 1, 2015 09:04 PM
