Water leak....
Old Jun 10, 2009 | 12:38 AM
purplehaze45's Avatar
Water leak....
On my 95 z28 i have a slow water leak that i cant seem to find... ive look and can never find a wet spot around anything around any of the water lines... i have to put about a cup of water every 2 days... anyone know of come common leaks?
Old Jun 10, 2009 | 06:50 AM
RUDEDOG's Avatar
It could be a slow head gasket leak. Been there done that.
Old Jun 10, 2009 | 06:59 AM
ACE1252's Avatar
Go to Autozone(using loan a tool) rent a coolant system pressure tester. When the engine is cool, pressurize the system to around 10 psi.(don't go above the rated cap pressure or you can cause a leak and damage the cooling system). See if you can spot a leak....if not it may be internal.
Old Jun 10, 2009 | 10:07 AM
thanks ill try that
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Sep 27, 2015 01:07 PM
