Warning about Accel "36" lb injectors
Old Jul 28, 2006 | 10:49 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
FWIW I've had 2 cars come in for tuning with Accel "36" lb injectors (designated by a printed number on the injector), which actually turned out to be 24lb/hr injectors.
Just something to be cautious of.
Old Jul 28, 2006 | 11:21 PM
Dave '97 Z28 M6's Avatar
Re: Warning about Accel "36" lb injectors
That's not good!
Old Jul 28, 2006 | 11:28 PM
3DFORMULA's Avatar
Has this information been forwarded to accel? I was considering some.
Old Jul 28, 2006 | 11:58 PM
CSJTA's Avatar
I have them in my car now, how can I tell if there 24's?
Old Jul 29, 2006 | 12:01 AM
Chrisbequick's Avatar
How can you tell they're 24s? What fuel pressure are you testing them at?
-Chris
Old Jul 29, 2006 | 12:59 AM
INTMD8's Avatar
I should have been more specific. Stock fuel pressure regulators (43.5psi)
When programmed as 36lbs/hr, cars would barely run they were so lean.
As I've allready seen this problem once before, I changed the injector constant to 24lbs/hr and the cars ran perfectly with 128 blm's
Old Jul 29, 2006 | 09:34 AM
CSJTA's Avatar
Maybe I got lucky and got the real 36ers, I've been running mine for a while now, bought from Summit if I remember correctly more than 2 years ago, and they have propelled my car to the number in my sig with no more than 80 percent duty cycle and not goin lean, so maybe I got lucky.
Old Jul 30, 2006 | 11:51 PM
OneFlyn95z28's Avatar
I refuse to use accel injectors now. I had six bad sets out of eight(leaking or not even flowing).
MSD, Holley, Seki and the Racetroix line are good choices
Old Jul 31, 2006 | 12:06 AM
tritonium's Avatar
I bought Accel 30# injectors ....
Heads will roll if this is the reason my car is running so lean.......
http://web.camaross.com/forums/showthread.php?t=460004
What you guys think? Possibility?
::Side note ANYONE know where i can buy new LT1 water pump bolts? ::
Old Jul 31, 2006 | 12:59 AM
madwolf's Avatar
Accel injectors are absolutely terrible. They are inconsistent and they have stuck open NUMEROUS times causing engine failure due to the excess fuel. Nobody listens though. :blah:
Old Jul 31, 2006 | 01:03 AM
tritonium's Avatar
I suppose I should have done more research on my injectors ... Thanks for the confirmation though - is there any way to test them - other than sending them out - Should I Simply get rid of them now and replace them? If so with what type of 30# injector?
Old Jul 31, 2006 | 01:06 AM
madwolf's Avatar
You can probably have them flowmatched to ensure even flow, something that you shouldn't have to do with new injectors. The ones that failed weren't bad out of the box though.
Old Jul 31, 2006 | 01:09 AM
tritonium's Avatar
If i were to use my stock chip which was for a 1993 camaro ( i think those are 24#'s that should run right - there is no difference between chips so maybe its not the injectors..
Old Jul 31, 2006 | 05:35 PM
I could not get two of the sets even close to matching
BTW I got some WP bolts from the dealer
Old Aug 6, 2006 | 07:47 PM
tritonium's Avatar
The Car Now Is Running Right!
Injectors....
Bad - Brand New Acel Injectors... That Are On Their Way Back To Summint For New 30# Svo Injectors.. Everyone Seems To Like The Svos And Have No Problems.!!!!!
Bottom Line
Do Not Buy Accel Injectors!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
13qtr
Oct 28, 2016 08:11 PM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
Slayer
Aug 17, 2015 03:55 PM
