Warm up car to do a compression test?????
Old Mar 11, 2007 | 11:14 AM
mrmint69's Avatar
My Chilton manual say to do a compression test you warm the engine to normal operating tempurature. Then disable the ignition system & disconnect all spark plugs. How am i to remove spark plugs from a car that is this hot? I think they must be talking about an engine out of the car. What is the right way?
Old Mar 11, 2007 | 12:33 PM
archangelus2's Avatar
Cool
I've been doing compression tests on my cold engine on and off for a month. If you want a REALLY accurate comparison of all the cylinders then yah, go ahead and try to do it warm (good luck). But if you are just trying to make sure the engine is in relatively good health a cold compression test is fine. The thing that seems to have made the biggest difference in my compression tests (other than a warped intake valve) was how much juice the battery had in it. If you crank it over too many times or have a low battery the engine will crank much slower and give you a much lower reading. That's my two cents anyway.
-Gabriel
Old Mar 11, 2007 | 12:34 PM
96ZCamaro's Avatar
I beleive that it is fine to do a compression test without your motor warmed up. At the least it'll give you a basic idea of what the compression is.
Old Mar 11, 2007 | 02:06 PM
OBE1 95Z28's Avatar
The ideal is a warm engine as this lets the pistons and rings expand to provide the best sealing. I believe a cold compression test is fine as I'm looking for variance between the 8 cylinders.
Old Mar 11, 2007 | 02:10 PM
Warm is how it is done, but if you can't, do it cold.
Injuneer
Dec 15, 2014 09:36 AM
NewsBot
Dec 3, 2014 12:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
naaz90
Jul 27, 2002 08:22 AM
