Wana use a 97 opti on my 93 motor
Old Sep 14, 2005 | 02:01 PM
93transam1234's Avatar
I am pretty sure i read that i would need a new timmingbelt cover to do this. How hard is it to do.
Can i just swap the guts out of the 97opti into the 93opti?
Old Sep 14, 2005 | 02:03 PM
Re: Wana use a 97 opti on my 93 motor
It will take a lot of items to swap, including the cam (if the 93 is stock).
http://para.noid.org/~muttvette/opti.html
Old Sep 14, 2005 | 02:35 PM
Are the insides of the 2 the same?
Old Sep 14, 2005 | 03:20 PM
They are not identical.
Old Sep 14, 2005 | 03:26 PM
LJ93Z28GM's Avatar
front cover, harness, timing chain set, different cam dowel pin, setup a vent for the opti, I am sure I might be missing something else.
I have a 93 and I did not see it worth it to make the so called up grade.
Old Sep 14, 2005 | 03:44 PM
Let me clear up what i want to do a lil.
I have in my car now a 93 opti, i have left over from the swap i did my old 97 opti. I am gettnig a bad studder at 5k+ rpm's.
I want to swap just the cap rotor and optical sensor from my 97 opti into the 93. Can i do that with out anyproblems or are those pieces not the same.
Old Sep 14, 2005 | 04:59 PM
Pretty sure the cap and rotor will swap as people have done vented cap conversions. Not sure about the sensor.
HectorM52
Jul 30, 2017 11:46 AM
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
2ponchos
Jul 26, 2002 10:45 PM
