Vortech vs. Trickflow elbow
You won't get a performance gain with either, so I would go for whatever is more visually appealing to you. I have the Trickflow ceramic coated elbow, it looks good polished up and fits well over the stock TB.
The dividing wall in the Vortech doesn't seem to be necessary. It just eats up flow area in the tube. Maybe with forced induction it helps smooth the flow between the MAF and the throttle body, but even that isn't clear.
ive been wondering about the little dividing wall. Sounds like i'll be better off with the trickflow. I remember though a while ago, that one of them does not fit so well on a 58mm throttle body, and that the intake elbow is smaller than the throttle body openings?
You would have that problem with either the Vortech or Trickflow. I have had both elbows with the SLP Intake and I had to cut the elbow on both. I ended up keeping the Trickflow due to the divider wall in the Vortech. I did not want it to interfere with my nitrous nozzle that I mounted in the elbow.
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
