Vortech or Trick Flow intake elbow???
Old Mar 18, 2005 | 10:59 AM
MILESF's Avatar
Question Vortech or Trick Flow intake elbow???
Is one better that the other? If so, why? I'm planning on replacing my stock intake elbow and want the best replacement.
Thanks.
Old Mar 18, 2005 | 11:48 AM
CamaroBoy96Z28's Avatar
Re: Vortech or Trick Flow intake elbow???
I'm going with the Trickflow. No partition running down the center of the elbow like the Vortech which interferes with airfoils if you have one.
Old Mar 18, 2005 | 12:03 PM
dirtybird96's Avatar
If you ever plan on runnning n2o get the trick flow. Its a p.i.a. to put a nozzle in the vortech
Old Mar 18, 2005 | 12:07 PM
IXLR894Z28's Avatar
I have the trick flow and I like it, but it will not work with a Jet Hot airfoil.
Old Mar 18, 2005 | 12:09 PM
Brian Sutherland's Avatar
I like my trick flow because it is ceramic coated and in my opinion looks nicer
Brian
Old Mar 18, 2005 | 12:13 PM
SantaCruz163's Avatar
Where can you buy a Trick Flow elbow?
Old Mar 18, 2005 | 12:22 PM
OutsiderIROC-Z's Avatar
I have the Trick Flow piece on my Z with a heat barrier coating inside and out and I like it. Stays nice and cool too.
Old Mar 18, 2005 | 12:35 PM
IXLR894Z28's Avatar
I ordered mine from summit. 79.00 ish for the ceramic coated one.
Old Mar 18, 2005 | 02:02 PM
Soccerbum21's Avatar
i was looking at the powercoated black trick flow for mine. i just like the all black intake look with my moroso cold air.
summit has that one for about 10 bucks less than the ceramic one i believe.
Old May 2, 2005 | 10:18 PM
ak_WRX_Z28's Avatar
i just put a trick flow intake elbow, and the stock intake doesn't fit too well now. well this be worse with my soon to be installed K&N CAI? what can i do to fix it? trim the coupler? thanks!
Old May 3, 2005 | 07:06 AM
Derrick Redd's Avatar
Smile Re: Vortech or Trick Flow intake elbow???
I have the Trickflow elbow with a K&N CAI and the fitment was fine.
Old May 3, 2005 | 06:01 PM
80TA's Avatar
I have trick flo not on yet.I have vented opti and don't feel like drilling into it.Can I drill in farther upstream like in my air induction tube.
Also does the delteq system need a vented opti? Is it to protect the optical part or just the cap and rotor and couldn't I pull vacuum from another spot in the vacuum harness?
Old May 3, 2005 | 06:51 PM
guywithaZ's Avatar
Yeah I didn't like that there was no port for the opti vent...debating on getting the 1LE elbow...
EDIT: I have the trick flow...
Old May 3, 2005 | 07:35 PM
Tibbys96Z's Avatar
i like the trick flow. it is very easy to drill the hole.
http://memimage.cardomain.net/member.../309664_38.jpg
http://memimage.cardomain.net/member...64_59_full.jpg
Old May 3, 2005 | 07:41 PM
BrandonKeith's Avatar
i got the trickflow and i didn't have to drill for my opti vent, my opti vent was relocated before i got the car to a separate place on the intake. possibly had simmilar mods before i bought it.. and the only fitment i had trouble with is if i want to take out my air box, it's just a little tight, so i pull the elbow from the TB and everything moves just fine.
