Voltage drop during high RPM's?
Old Aug 31, 2009 | 12:06 AM
95Blackhawk's Avatar
Is it normal for the voltage to drop about 1 volt from 13.1 to about 12.1 during high rpm operation?
As a side note, if I disconnect the battery while the car is running, the car does not want to run above 2000 RPM. At 2K, it's as if you hit a rev limiter with the car bucking.
Is this an indication of an alternator going ?
Thanks,
Ben
Old Aug 31, 2009 | 06:10 AM
Do not disconnect the battery while the car is running. That's a good way to ruin a good alternator.
Where are you taking your readings?
Old Aug 31, 2009 | 07:26 AM
disconnecting has been accidental but wanted to relay the results of what happened.
I am taking readings through the PCM and logged via datamaster.
Old Aug 31, 2009 | 01:03 PM
I think it is fairly normal to see this (though it may not be the best thing). Seems like I have seen previous threads with the same question. There seems to be some common voltage loss through the ignition switch or it's connection.
Old Aug 31, 2009 | 03:04 PM
I wanted this question to stand alone. Well, sounds like I can eliminate this as a possible problem.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
edman
Jan 22, 2015 02:45 PM
97SSdude
Dec 31, 2014 07:43 PM
