Video - My LE2 Journey
Old Apr 25, 2007 | 09:03 PM
  #16
Daniel6718's Avatar
gotya...freq oil changes and watchin the pressure is key..what you set the shift points at?
Old Apr 26, 2007 | 05:53 AM
  #17
rawbutt's Avatar
WOT shift points are 6400-6500
Old Apr 26, 2007 | 07:10 AM
  #18
Javier97Z28's Avatar
Moderator
Originally Posted by rawbutt
daniel...
i had a feeling somebody may point that out as you point out, i did get out of it before the WOT shift point. it's my daily driver and want it to last as long as possible before the next rebuild so i'm tryin' to break it in nice and slow until i get some miles on it.
Break it in HARD... not "nice".
My car runs like a raped ape and my 355 was not broken in easy.
Old Apr 26, 2007 | 07:38 AM
  #19
rawbutt's Avatar
we're gonna check the oil pressure out this weekend...seems a little low to me and another reason i'm tryin' not to beat up on it too bad yet. it might be the sending unit...gonna replace that first.
Old Apr 26, 2007 | 08:16 AM
  #20
foggedz's Avatar
Whats the oil pressure doing?
Old Apr 26, 2007 | 03:59 PM
  #21
mattybz28's Avatar
yeah, im strongly considering that..just throwing some MT DR's on my stock rims nah, wasn't me in CA....im clear across the map in S.C.
Where in SC?
Old Apr 27, 2007 | 06:32 AM
  #22
rawbutt's Avatar
oil pressure just doesn't seem to be as high as it was prior to this rebuild. it will get down a little below the 20 line now when it's hot, which still may be relatively normal, but it also won't get above 40, even when i give it a lot of rpm. the only time i see anything above 40 is first thing in the morning before it warms up. i don't think im in the "danger zone" or anything, but think it's at least worth trying a new sending unit and investigating a little this weekend.
also, to answer the other question, im in the columbia, sc area
Old Apr 27, 2007 | 09:05 AM
  #23
NightTrain66's Avatar
what oil are you running?
hopefully you have changed it after the build to get all the debri and assembly sube out of there.
It gets hot here in the summer so I run 20/50 oil. if you are using some real thim 0w10 sythetic oil, the pressure will be lower than usual.
Lloyd
Old Apr 27, 2007 | 09:16 AM
  #24
rawbutt's Avatar
I think I have changed the oil 3 times already and only have about 300 miles on it definitely am not taking any chances there. It definitely gets hot here in S.C. Only thing I have run so far is 10W-40, but have considered going a little thicker and seeing how it looks. May give that a try this weekend. Thanks for the suggestion.
Old Apr 27, 2007 | 10:10 AM
  #25
Daniel6718's Avatar
i use striaght 30 weight...good luck with it when it gets hot it doesnt get thin like other oils...typically every lt1 ive seen thats higher milege with low oil pressure is simply a work out oil pressure switch
Old Apr 28, 2007 | 10:00 PM
  #26
rawbutt's Avatar
it was the oil sending unit....got pressure out the a$$ now even with my 10W-40...woo hoo!
Old Apr 29, 2007 | 03:21 AM
  #27
tnmotown's Avatar
sounds sweet!!
Old Apr 29, 2007 | 08:54 AM
  #28
Z-RATED94's Avatar
That's good to hear, seeing all the nice parts you have. I'd hate for you to puke it before its time.
Old Apr 29, 2007 | 12:05 PM
  #29
rawbutt's Avatar
yeah, it was definitely nice to see see that pressure come up....can breathe a little easier now
Old Apr 29, 2007 | 07:05 PM
  #30
irocbsa's Avatar
Congrats! Sounds like a great set up. It gives me motivation to get my project moving. Let us know when you get numbers/times.
