vibration issue...
Old Apr 29, 2004 | 09:27 PM
N20LT4Bird's Avatar
vibration issue...
I am posting this question here in hopes of catching some insight of some sharp guys on a particulary troublesome issue. I posted in this forum because I have checked the all of the obvious issues and I am not looking for the "did you check the u-joints?" answer.
Here it is. I have a high rpm vibration - out of the blue. Read my sig and that will tell you what were working with. I initially thought it was a drivetrain issue and even went so far as to replace all the bearings in the rear because I felt roughness in the pinion yoke. Upon further review, the vibration is not related to speed as much as rpm. I feel it in the shifter and the seat when I am at a higher speed AND higher rpm. Now, I am leaning more towards engine vibration as the car is not pulling as hard as it used to. Its not a huge power loss, but noticeable. The vibration only comes in under high speeds and high revs though. If your cruising at 75 in 6th - nothing. 75 in 4th - yes vibration. Im stumped. Could it be a valve sticking, causing an unbalanced engine situation? What else?
Old Apr 29, 2004 | 10:00 PM
kmook's Avatar
Advanced Tech Moderator
What are "all of the obvious issues" that you have tested and ruled out?
Old Apr 30, 2004 | 12:28 AM
slashz28's Avatar
driveshaft needs to get balanced maybe?
Old Apr 30, 2004 | 05:53 AM
N20LT4Bird's Avatar
I have not gotten into the engine yet, but I think I have ruled out drivetrain.....I did not have the shaft balanced becasue the vibration came out of the blue and the weight is still on the shaft.
Old Apr 30, 2004 | 06:34 AM
kmook's Avatar
Ok just checking, becuase if you havent looked at the engine side it should be discussed in a general engine tech forum. Transfering, thank you.
Old Apr 30, 2004 | 07:56 AM
93transam1234's Avatar
on my pld Caprice my balancer (the thing the belt goes around) got a little crocked, it was starting to get loos. I could look at it while the car was running and see it wobling like bent rim.
I wouls say take a look at all the belt pullies and make sure they are not wobbling around at all.
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
Apr 16, 2015 09:57 AM
