Vibration dampner?
Old Mar 14, 2005 | 09:24 PM
Sweetred95ta's Avatar
Vibration dampner?
Do I need to run a dampner? I have an underdrive pulley and can run it w/out the dampner. Is this bad? The motor is internally balanced and blue-printed.
Benji
Old Mar 14, 2005 | 09:59 PM
rskrause's Avatar
Moderator
Re: Vibration dampner?
Yes, you need one. It dampens torsional (twisting) vibrations in the crank. A balanced rotating assy. just refers to balancing the reciprocating weight of the pistons and rods. The crank will stilll still twist/untwist regardless of balance. Without a harmonic balancer your crank will not last too long!
Rich
Old Apr 19, 2005 | 03:14 PM
Been thinking about this, I have the underdrive puller and it fits down inside of the dampner. How does the dampner still do its job if it is not connected to the belt? Should I pull the udp off there and just run the stock dampner? I don't want to spin a bearing or break a crank.
Thanks,
Benji
Old Apr 19, 2005 | 05:57 PM
rskrause's Avatar
Moderator
The damper will work fine as long as it's connected to the crank,
Rich
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
Apr 16, 2015 09:57 AM
