vibration after clutch instal
Old Mar 22, 2006 | 05:25 PM
TransAm396's Avatar
well i put my clutch in today. Had my flywheel resurfaced too. Now when i drive..it seems to vibrate alot. I know my ypipe is hitting the floor, i can hear it. But the vibration gets deep when im up around 5k+. Whether im stopped(REVVING it) or going..i can feel it through the shifter and my pedals..and steering wheel. Its a pretty deep viration.I know it isnt the driveshaft cuz it does it in neutral..any ideas?
Old Mar 22, 2006 | 05:39 PM
96flame's Avatar
Re: vibration after clutch instal
Did you line the coloured mark on the pressure plate up with the white X marked on the edge of the flywheel? Its also possible that the pressure plate you got wasn't balanced properly. Is the clutch the only change you made?
Old Mar 22, 2006 | 05:45 PM
TransAm396's Avatar
yeah its the only thing i replaced...i just put the pressure plate on and torqued it down. it vibrates with the clutch pedal in and out
Old Mar 22, 2006 | 06:04 PM
96flame's Avatar
Go back to the first question I asked. Did you line up the colored mark on the pressure plate to the white X on the side of the flywheel?
Old Mar 23, 2006 | 01:51 PM
TransAm396's Avatar
well i took it back apart..and i compared the old pressure plate to the new one and the old one has drill marks (where it was balanced) and the new one doesnt...could that be it?
Old Mar 23, 2006 | 01:53 PM
Cmr0z28's Avatar
wrong forum.
Old Mar 23, 2006 | 01:56 PM
valter's Avatar
New flywheel/PP should be balanced to the old one/PP, since your engine is externaly balanced to the old one too. I got lucky with my aluminum flywheel without balancing it.
Old Mar 28, 2006 | 01:07 AM
TransAm396's Avatar
well pp is now balanced..perfectly...and the flywheel is all good. vibrations still there...maybe it could be from my ripped tranny mount? its not completely broken..but its on its way. Hopefully that could be it.
Old Mar 28, 2006 | 08:17 AM
wrd1972's Avatar
I have done many clutch installs and I never referenced the painted dot found on the PP to the flywheel. Mainly because I have no indicator on the flywheel to reference it to. After 3 or 4 PP's I have never had what you describe.
I doubt that it could be your PP, I would lean more toward the craftsmanship of resurfacing the flywheel or maybe the PP not being torqued correctly. Did you put a shim behind the flywheel? If so maybe the shim is bad.
What brand clutch?
Old Mar 28, 2006 | 11:59 AM
TransAm396's Avatar
no shim..and the PP was done ****ty the first time....but i got it redone by a very good shop...becuase it was off a little bit. But it doesnt seem like its coming from there at all anymore. cuz its doing it exactly the same. Not to mention it is torqued perfectly this time. Last time i might of been a lil sloppy(never had this vibration) only thing I can think of is i remember tearing the tranny mount but not all the way. Hopefully that could be it.
BPS
9
Mar 5, 2015 10:51 PM
karnykamaro
Feb 2, 2015 01:37 PM
HectorM52
Jan 30, 2015 11:08 PM
mattszm6
Dec 14, 2014 07:09 AM
squarehead
Nov 21, 2014 08:02 PM
