Vibration 3000 rpm +
Old Jul 21, 2007 | 01:10 PM
JustNO's Avatar
My engine is internally balanced. I feel a vibration after 3000 RPM. After I changed my first clutch Spec 3, I simply replaced with a Spec 3+. Do these clutches came balanced? Could that be the reason of vibration?? If so when I take out the clutch, it vibration will be dissapear? Or could my engine messed up ?
Hope you understand my english
Deniz
Old Jul 21, 2007 | 03:51 PM
11secgen's Avatar
did you remove the flywheel?,if so did it you mark its location to the crankshaft so you could make sure it went back on the same way?
Old Jul 21, 2007 | 04:05 PM
JustNO's Avatar
No I didn't remove the flywheel. I just get a new friction plate and replace it. I only swap the clutch. This makes sense? Or do I have a vibration issue related to another thing ? Misfire ?
ryanhilsgen
9
Sep 21, 2015 07:34 PM
damnyankee36
Sep 9, 2015 07:06 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
1slow93z28
Sep 1, 2015 06:22 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
