vert problems
Old Nov 30, 2003 | 02:27 PM
Detroit808's Avatar
vert problems
How can I fix the sag in my vert top? It is no longer pulled tightly around the rear glass and looks slightly draped. someone once gave the answer, "Yes it can be pulled tighter. Just unscrew the liner moldings and you will see how." however, I'm a vert top newbie, so I need more detailed instructions before I touch anything!
Old Nov 30, 2003 | 02:59 PM
QCKZ28's Avatar
my advice --------------> go to a upholestry shop that specializes in vert tops. see what they will charge to fix it. i do all the work on my car heads/cam/tranny, and i had a shop repair my top.
jesse
Old Nov 30, 2003 | 04:54 PM
Detroit808's Avatar
I'm willing to put in the work to restretch it if I can do it myself. If anyone can explain more specifically how to do it, I'd like to try it myself before I go to a shop.
Old Nov 30, 2003 | 07:44 PM
Detroit808's Avatar
Is this just not the kind of project ordinary people attempt?
Old Dec 1, 2003 | 01:30 PM
Detroit808's Avatar
let's try this again
Old Dec 1, 2003 | 06:42 PM
Detroit808's Avatar
anyone care?
Old Dec 2, 2003 | 12:22 AM
Detroit808's Avatar
please! someone has to know!
Old Dec 2, 2003 | 03:02 PM
Detroit808's Avatar
please?
Old Dec 2, 2003 | 06:07 PM
Zrag's Avatar
yes you were right in your first post. release the top as it were going down about half way down so that there is slack. then loosen the screws on the top where the metal plate is and pull.
just a little or else the top will not go down. There is one last adjustment in the trunk, again a metal plate with screws, loosen and pull just a bit. Try olny one of those first and see the results then do the other if needed.
Old Dec 2, 2003 | 06:22 PM
Detroit808's Avatar
awesome! I'll take a look at that later today! thanks!
KYWes
Apr 24, 2015 09:17 AM
Izod
Sep 16, 2002 01:35 PM
RYANA
Jul 27, 2002 06:36 PM
dreamer1q
Jul 9, 2002 05:37 PM
