vented optispark
Old Jul 23, 2006 | 07:36 PM
z28-06's Avatar
vented optispark
I have a 1994 unvented and it has gone out. Do you think it would be a good idea to go with a vented. i would then have to go with everything seen on this site http://para.noid.org/~muttvette/opti.html i am looking to spend under 400$ and dont think that is possible if i switch to vented
Old Jul 23, 2006 | 07:56 PM
ShowStopper540's Avatar
Re: vented optispark
my honest oppinion is to stay with what has worked, im new to OWNING the car, i own a 96, and these parts can get pretty pricey, summit offers a nice "gm performance" opti for about $290, so you MAY be able to switch it over, but its still going to be pricey and more work...in the end, its all about what you feel is right for your car
Old Jul 23, 2006 | 08:02 PM
sbs's Avatar
sbs
You have the parts list, look up the prices. http://www.gmpartsdirect.com/
The other two options for upgrading to a vented opti are the MSD and the Dynaspark.
All three options are going to be more than $400.
Just replacing the stock opti will cost you about $400 if you don't replace the WP.
Old Jul 23, 2006 | 08:35 PM
z28-06's Avatar
it is about 520$ just for parts. plus i dont even know where to get a longer dowel pin. i think i might just get the gm unvented optispark
Old Jul 23, 2006 | 09:03 PM
Well, you would have to swap the cam, so a longer dowel pin would probably be in it.
If you buy a new MSD billet opti, it will have the vents and you won't have to swap anything else (you will have to buy the vacuum harness and a fitting, though).
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
Z Power
Sep 19, 2015 11:19 PM
