Vented opti vs. non-vented
Old May 17, 2004 | 12:47 PM
My Red 93Z-28's Avatar
I have a '93 and need a new opti.
I know I can swap in a vented opti, but I have to convert a few things over.
Is the vented opti worth paying the extra money to swap everything over or can I be fine with just going with the non-vented.
Money is a factor so I was wondering if I should spend the extra for the vented?
Old May 17, 2004 | 12:51 PM
Releacez28's Avatar
RE: Vent or not to vent
It's up to you, but i (knock on wood) have not experianced opti failure since i went with the newer 96-up? Vented opti.
good investment to make the switch.
Old May 17, 2004 | 01:07 PM
Toade21's Avatar
I have heard that the vented opti actually will fail more often. The reason being water gets in it eazier, so the non-vented is actually better. How did yours go bad? I once had a misfireing after driving through a large pool of water, but after about 1 week, and several getting on it's, it fixed it self.
Old May 17, 2004 | 01:55 PM
when rebuilding my engine, my buddy noticed the cap was bad, but he had a spare. Unfortunately maybe that was bad too even though it looked good.
It has to be the opti because we have checked everything else:
1. compression test - 140
2. switched injectors around
3. adjusted rockers
4. new plugs and wires
The car kind of jerks around unless you get on it, and it pops when you let off the gas.
Old May 17, 2004 | 02:21 PM
Red96Lt1's Avatar
161K, still the origonal vented opti. BTW, 95's had vented opti's. I personally don't think it's worth changing everything out.
Old May 17, 2004 | 02:28 PM
alright.
Thanks for the replies
I'll go with the non-vented
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
tdigger9899
Sep 7, 2015 10:56 AM
whitehooptie
Jul 12, 2015 06:10 PM
Jul 10, 2015 02:23 PM
