vented opti vented correctly?
Old Jan 12, 2009 | 05:59 PM
95Blackhawk's Avatar
Is there a proper way to vent the opti? What I mean is should the fresh air absolutely come into the rotor side or into the distributor side before exiting to the intake manifold?
Also, what happens if you don't vent it?
I ask because I am having absolutely terrible results with the last 4 optis, all of which seem to last under 1500 miles and this is on 2 completely separate engines. All are AC Delco. Granted the latest one I only run over 3K RPM and consistently take it to 6300 RPM. Still should think it would last 10K+ miles (which would be many years for me).
Ben
Old Jan 12, 2009 | 06:03 PM
sbs's Avatar
sbs
Which part failed?
Old Jan 12, 2009 | 06:49 PM
http://shbox.com/1/opti_vacuum_harness.jpg
http://shbox.com/1/opti_vacuum_hose.jpg
http://shbox.com/1/opti_vacuum_conn.jpg
Old Jan 12, 2009 | 08:36 PM
Originally Posted by steve9899
Which part failed?
Optical encoder...always.
Shoebox, that is the way I set it up. Thanks for confirming.
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
thenewkid
Nov 27, 2014 09:41 AM
