valvetrain guys help please
Old Apr 14, 2006 | 04:27 AM
Zeueses 97 RamAir's Avatar
Ok I installed full roller pro comps shaft mounted rollers 1.52 steel rockers im using the polylocks for aluminum rockers, because the poly is to tall for valve covers so today the rocker stud snapped on the head right down to the nut where i got lucky and just zapped it off, qwuestion what could have caused this to snap overtightning the polylocks maybe...
Old Apr 14, 2006 | 05:26 AM
MeanGreen97Z's Avatar
Re: valvetrain guys help please
Wow.... what size stud was this? There might have been too much stress on the bottom of the stud. Try going to a tall valve cover and relocate the altenator. Use the original locks. Definately not something I have seen before.
Old Apr 14, 2006 | 06:21 AM
3/8 stu what does a taler valve cover have to do with them snapping i cut the valve cover so they can clear the rockers.
Old Apr 17, 2006 | 04:20 PM
You said the rockers didnt clear the valve covers so you had to use the poly locks from the rollers to make them work. I say use the original equipment that came with the shaft rockers and go to a taller valve cover to clear them. Mixing and matching parts like that causes the type of problems you are having.
HectorM52
Jul 30, 2017 11:46 AM
carguy0119
Apr 11, 2016 11:11 PM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Red97LT1
Aug 7, 2002 05:45 PM
