Valvetrain
Old Feb 15, 2006 | 09:05 PM
mustangmuncher's Avatar
Valvetrain
224/230 503 Camshaft
What valvesprings etc.. I was thinking the CRN-10308-1 from summitracing, comes with shims, locks and retainers, fits without machining, should be strong enough no?
Pushrods, if the stock ones spec out fine, is there need to worry about new ones?
I plan on keeping the stock water pump, what timing chain?
I already have 1.6 RR's, not worried there, and I assume the OE valve covers are good to go?
Thanks guys.
-Eric
Old Feb 15, 2006 | 09:34 PM
97bowtie's Avatar
Re: Valvetrain
The Crane 10308 is a good spring and would work well with that cam. Stock pushrods are fine. The stock timing set is OK as well, but I'd pick up a new chain. You might look into the LT4 timing set as well. Stock valve covers are fine.
HectorM52
Jul 30, 2017 11:46 AM
69z-28
Jan 29, 2016 10:46 PM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
z28ponyeater
Mar 1, 2003 12:11 AM
