are valves this big possible on an lt1 heads...
Old Jan 15, 2005 | 09:17 PM
Seal's Avatar
I'm just curious, cuz the guy whos building my motor told me the heads i got sounds huge for an lt1 cast... FYI they are 2.080/1.650 bowl ported...
is it possible to have valves taht big on a lt1 alum. head?
they are these btw
oh and whats 'bowl ported' ?
http://web.camaross.com/forums/showt...65#post2739165
Old Jan 15, 2005 | 10:16 PM
snakeatinZ's Avatar
Re: are valves this big possible on an lt1 heads...
Bowl ported I belive is so a dual valve spring can be used....? correct me if I am wrong.
Old Jan 15, 2005 | 10:18 PM
Seal's Avatar
hmmmm not sure?
I've heard of ppl using those without any work to heads I think
Old Jan 16, 2005 | 12:26 AM
TQdrivenws6's Avatar
The bowl is the area inside the intake runner right before the valve, nothing to do with the spring pockets. Valves that large would need atleast new seats, but as with most things, its probably possible with enough money.
Seal's Avatar
well i got'em for 800 bux
Old Jan 16, 2005 | 02:16 AM
Spinner's Avatar
Not on an LT1 head, even with recut valve seats. A 2.08 is a monster, and there just isnt room.
Old Jan 16, 2005 | 07:38 AM
Hmm...there have been some posts of people with 2.08 valves.
If Seal would bother to search (which he never seems to do), he would not have to ask.
Old Jan 16, 2005 | 09:04 AM
96capricemgr's Avatar
Bigger is not always better either, at some point shrouding becomes a problem.
Old Jan 16, 2005 | 09:27 AM
Seal's Avatar
whats search?
Spinner thats what confuses me, you are the 2nd person to say that, but this guy has a head shop (CFM) and told me these are lt1 alum heads...
Old Jan 16, 2005 | 09:30 AM
Seal's Avatar
ok, i actually searched, and found a couple use them
man, this search thing actually works!
Old Jan 16, 2005 | 12:50 PM
96m6lt1's Avatar
i thought the 2.055 was the largest valve you can fit in a stock lt1 head!!the afr head can be fitted with a valve that size.
Old Jan 16, 2005 | 01:34 PM
Spinner's Avatar
But not with a 1.65 exhaust valve also. Thats almost .25 inches more valve width then stock, there just isnt that much room there
Old Jan 16, 2005 | 01:54 PM
atljar's Avatar
My AFRs are 2.08/1.60, and that seems like fairly tight spacing.
Old Jan 16, 2005 | 06:29 PM
Seal's Avatar
well see what happens then...
guess searches dont answer everything
Old Jan 16, 2005 | 08:20 PM
hvyss's Avatar
I am running stock LT1 castings (iron) on my 96 Impala SS. They are Agistino ported and have 2.05/1.60 valves in them. I posted the same question reasontly and was told 2.05 is the largest seen on stock castings. There is maybe a sheet of paper between the valves. I have never seen 2.08's in stock castings aluminum or iron.
HVY SS
