which valves?
Old Jan 17, 2005 | 12:42 PM
limige's Avatar
which valves?
i'm putting together your basic street motor.
stock lower new rings and bearings and a 230/236 cam on a 112.
headers, ported intake and larger tb.
i'm porting my own heads and doing an all out job. i've polished the chambers, took out all the sharp corners, narrowed the intakes and flattened the roofs as well as teardroping around the valves.
what i'm not sure about is two things.
should i open the valve seats or stick with stock sizes?
should i spring for a set of ferra's??
not sure what the gains would be on the new valves and if that cam could make use of bigger valves.
thanks,
mike
Old Jan 18, 2005 | 08:48 PM
limige's Avatar
Re: which valves?
so what? nobody can tell me if i'll gain hp on that cam if i open up to larger valves?
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
