Valve train problems on new engine
Old Sep 28, 2007 | 09:28 PM
  #31
Jim D's Avatar
Originally Posted by pizzi-man
Zero lash is when the push rod makes contact with the lifter and there is no play between rocker and lifter via the push rod. If your not paying attention you could be colapsing the lifter and then putting an additional 1/4 turn is way too much. Loosen the rockers and then tighten them down while lifting the rocker off the valve until you can't lift the rocker. Then your at zero lash . Now it's your 1/4 turn or 1/2 turn to preload the lifter.
Thanks for that tidbit...I struggled trying to set up 0 lash (having never done this before). And your explanation is like one of those "Duh, why didn't I think of that?" slaps in the face. I appreciate the suggestion to hold the rocker off the valve until I can't.
AdsoYo
May 2, 2018 03:21 AM
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
