Valve tip height above retainer?
Old Apr 27, 2006 | 09:42 AM
94badrag's Avatar
If I use +.05 locks with my 918 springs the tip of the valve will decrease.
What is the minimum amount of valve tip needed so I can run my SA 1.6
RR's?
Some say I should use NSA RR's here. WHY??
Old Apr 27, 2006 | 12:13 PM
94badrag's Avatar
Re: Valve tip height above retainer?
Hello,help
Old Apr 27, 2006 | 12:14 PM
Loadre's Avatar
With the +.05 locks you MUST run NSA rockers. There is not enough meat on the valve tip to let the SA rockers do their job, and they can easily pop off.
Old Apr 27, 2006 | 01:11 PM
94badrag's Avatar
Whats the diff in the design between the two rockers, NSA & SA?
Can I just put guide plates with the SA RR's??
Old Apr 27, 2006 | 01:24 PM
Loadre's Avatar
SA use small guides beside the roller tip that keep the rocker centered on the valve.
NSA use guideplates to keep it aligned on the valve.
Can't use guideplates and SA.
Old Apr 27, 2006 | 02:02 PM
stroked383z28's Avatar
Don't bump your post to the top just because you haven't received a response in three hours.
http://web.camaross.com/forums/showthread.php?t=5485
Old Apr 27, 2006 | 02:42 PM
94badrag's Avatar
thanks for the bump
HectorM52
Jul 30, 2017 11:46 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
KamikaZ28
May 28, 2015 12:45 AM
nikolt1
Feb 27, 2015 09:10 PM
