Valve timing
Old May 7, 2004 | 05:54 PM
Marcus34's Avatar
Valve timing
iac flucs between 120 and 140 could somethin else be controllin this sensor or is it bad
can the opti control valve timing, my uncle ran a vacuum tester on it and it is leanin towards a late valve timing, would late valve timing cause the car to have an idle at around 500 rpms
Old May 7, 2004 | 07:55 PM
Josh-'04 GTO's Avatar
Re: Valve timing
Did you swap a VTEC into your car?
The PCM has control over idle speed, and ignition timing, among other things, but not over valve timing.
A vacuum leak is a good bet. That would play havoc with the idle.
Old May 7, 2004 | 09:24 PM
Counts that high mean that it is letting in a lot of air. Maybe you have an over-rich condition. Perhaps even a bad f/p regulator and you are sucking gas in through the vacuum control line.
Old May 8, 2004 | 06:59 PM
Marcus34's Avatar
we arent getting any vacuum in the engine would a bad opti control the vacuum in the car
Old May 8, 2004 | 10:12 PM
Maybe you can explain how a NA car could even idle without any vacuum reading?
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
